Samsung s23 Ultra no longer charging via plug
Winnie90
Hello,
My S23 is no longer charging via plug. I've cleaned it out, changed the plugs, cables and tried multiple points of access. It is charging via USB and through a powerbank, albeit slowly.
I've had the phone less than a year, is there anything I can do via EE to get this sorted?
Schockwave
@Winnie90 , Are you using the original plug and charger from the manufacture?
Hiya,
Yes, I've been using original plug and cables. Tried multiple others too.
Linzi_H
Hi @Winnie90
Thanks for letting us know you are using the supplied equipment.
I would suggest getting in touch with us directly so our technical support team can run some further checks.
Linzi
