05-05-2023 11:22 PM
My z flip 4 is starting to get bubbles under the screen protector, where the crease is, does anyone have any advice to what I can/should do?
06-05-2023 09:17 AM
OK thanks @Danjohnson502
I'd recommend speaking to our technical support team so they can run through some options with you.
06-05-2023 08:23 AM
Welcome to the community.
Is it a bubble on the screen, or on a screen protector?
06-05-2023 08:34 AM
Thank you @Christopher_G
It's the screen protector that came already places in the phone, it's just starting to lift on the left side where the crease of the fold is.
06-05-2023 09:17 AM
20-09-2023 01:42 PM
Mine has also started to do this did you get it sorted ?
20-09-2023 02:30 PM
20-09-2023 02:30 PM
Unfortunately I didn't, I ended up removing the screen protector as it was only the screen protector that had started to lose its glue, sorry
20-09-2023 02:34 PM
Did this effect your warranty at all because you removed it? Sorry for all the questions lol
20-09-2023 03:04 PM
So I had a little Google and apparently it doesn't effect the warranty, but don't hold me to that 😂, no worries I don't mind answering some questions
20-09-2023 03:12 PM
Ahh fab thank you for your reply 😊
