Samsung Poor battery perfprmance after Ui7 update
Ngolio1980
If your battery after the Ui7 update seems poor this is usually due to the self learn mode not kicking in after update, fix for it as so common is goto phone keypad, type in *#9900#, go down the hidden service menu list to Battery Status reset, select, then exit, soft restart device.
When rebooted battery life will be same as before and last much longer.
Peter_W
Hey there @Ngolio1980, thanks for sharing this 😊
Peter
