S22 restarting due to WiFi
_TheApeVine_
Afternoon,
I've had a Samsung S22 for just over a year with EE and it's started to restart every time it connects to WiFi.
Seems to work fine on mobile data, when you connect to a WiFi signal the battery drain goes through the roof and the phone restarts itself.
It's been updated to the latest version, and ideas?
Cheers
Northerner
Hi @_TheApeVine_
  • Run device care under settings
  • Clear the system cache
  • Ensure your phone and apps are updated.
Do you have this issue with all WiFi networks or just one.
Have you tried a factory reset.
Northerner
Hi @_TheApeVine_
