04-08-2024 09:50 AM
I am trying to set up wi fi calling and it’s not showing as an option
04-08-2024 10:58 AM
There may be slight variations between Android versions, but that's not where my Galaxy shows WiFi-calling. It's under Phone > Settings > WiFi-calling. (I think you're looking under Network Connections)
Call settings menu
04-08-2024 10:07 AM
Did you purchase the phone from EE direct?
Can you post a screenshot of the options where you think WiFi-calling should be?
04-08-2024 10:40 AM
Yes I purchased it from EE
04-08-2024 10:58 AM
Have you looked in the phone app settings? Samsung phones tend to hide it away there, and not in network settings.
04-08-2024 10:58 AM
Call settings menu
04-08-2024 11:15 AM
Thank you - your right - got it sorted - thanks again
04-08-2024 11:17 AM
Thank you - you were right - got it sorted now - thanks again
