S22
Rocky001
My S22 seems to take a long time to charge and if I am using it, it overheats to the point it is red hot too touch.  Does any1 else have this
7 REPLIES 7
Northerner
Hi @Rocky001
Contact Samsung repairs or EE repair
https://ee.co.uk/local-repairs
Youll likely need to pay for a new battery as it sounds like it has reached the end of its life.
Rocky001
I have only had it since January 2024
@Rocky001  It depends how much you’ve been charging it for.    The more you charge a phone the more life you take out of the battery.       If it’s getting hot that’s the battery that’s being over worked and draining fast so getting hot.   The device needs to be looked at if it’s getting to the point you can not hold it.
Rach_H
Hi @Rocky001,
Welcome to the Community!
How long have you had this phone for?
Rach
Since Jan 2024
Chris_S
Thanks for letting me know @Rocky001
Your phone would still be in warranty, so I'd recommend speaking with one of our technical guides.
You'd just need to call 150 then options 1, 3 then 1
Chris S
carguy143
The other option is to get a Samsung mobile repair booked. Mobile as in they come to your chosen work or residence and repair the phone in their van. I had a repair through the service and it cost me nothing, and only took the repairman about 40 minutes or so.
