15-01-2021 04:09 PM
Recently changed phones and couldn't log on to the MyEE App. Uninstalled it and searched the Google Play Store for it to reinstall. It's not visible on the Play Store from my Xiaomi phone. Confirmed with ee Tech Support that it's not compatible with these phones and I can't use it. Have to use the website instead to see my account. Apps for other phone providers are are available to Xiaomi users, so no idea why ee have either withdrawn their app from Xiaomi, or simply haven't made it compatible.
15-01-2021 04:53 PM
Hi @abayliss,
Please see There seems to be a problem... error when using My EE app on Xiaomi phones.
17-06-2021 04:19 PM
What an absolute disgrace. EE have recently changed something to force you into updating, but the update fails due to continued incompatibility. This means that the workaround of using the older working version has now been totally fukked. The EE app technical development team should hang their heads in shame.
01-07-2021 10:48 AM
I found I had this problem last week. I rang tech support who told me to uninstall/reinstall then said to contact Xiaomi when I couldn't see it in play store. Xiaomi said it was the fault of the app developer. So this morning I rang tech support again who are insistant that Xiaomi are blocking it. The guy told me to Google the app. **bleep**
01-07-2021 01:47 PM
02-07-2021 09:33 AM
My thoughts entirely. They are always trying to sell me one of theirs but they can bugger off. One thing I don't understand is why they are picking on Xiaomi or maybe there are other ppl out there with not so common phones that are having this problem too. Be interested to know
14-07-2021 07:42 AM
install aptoide store app then install my ee it works fine just done it on note 9
14-07-2021 09:18 AM
Cheers for that
14-07-2021 10:10 AM
The app shows up for me in the play store on my Xiaomi Mi 11 Ultra (Global) so it's not all Xiaomi phones.
Does it show up on the web version and allow you to install to your phone?
14-07-2021 10:32 AM
The link you posted says incompatable with my device
(redmi note 9 updated to android ver 11 same before on android 10)
But works fine on from aptoide store app version 4.53.0
so it looks like new app version 4.54.0 from google play store is not compatable with some devices both versions and the link work fine on my motorola g6
