27-01-2025 11:30 AM
I have recently moved my EE sim from my Apple device to my Samsung and mobile data is not working. I have mobile data active but it will not allow me to send messages, browse etc unless I am wifi. Any guidance would be welcomed
27-01-2025 01:10 PM
Hi there @Heathkl
Which Samsung device are you using? Do you get an error message when trying to access data?
Can you make calls and send texts?
Speak to you soon 🙂
27-01-2025 01:30 PM
Hi Leanne
I cannot make calls or texts , however a few texts have gone through but they take a very long time
Galaxy s22 Ultra
27-01-2025 02:43 PM
Thanks @Heathkl, are you using an eSIM or a physical SIM?
When you're on the lock screen too, does it show EE in the top left corner of the screen?
Peter
27-01-2025 02:54 PM
On the assumption that you have EE coverage and can make & receive voice calls, send & receive texts....
Try re-sending the EE-specific mobile data config from https://setup-ee.wdsglobal.com/internet
27-01-2025 03:34 PM
Hi @Heathkl
Is your Samsung phone from EE.
Are you in the UK.
27-01-2025 04:00 PM
its a physical sim and the lock scree shows EE but no indication of 4 or 5G
27-01-2025 04:00 PM
the phone is not from EE but the Sim is EE
27-01-2025 04:33 PM - edited 27-01-2025 04:34 PM
If it's showing EE that's a good sign @Heathkl , you'll need to switch off WiFi before it shows a 4G / 5G indicator too.
I would definitely recommend trying to download the internet settings @bristolian shared here.
If this phone has previously been used on a different network, then it may still be configured to that network.
As it's an iPhone you had previously too, often you'll need to de-register from iMessage in order to send normal texts, so this is worth checking out.
Peter
06-08-2025 10:15 AM
I've got a samsung 20 fe phone with a new ee sim card and it's not letting me connect my data when I'm trying to do it manually its only allowing me to connect to 2g/3g lite which won't allow me to use data without wifi
