Mobile Data not working!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-05-2021 09:11 AM
Phone: Samsung Galaxy S8 (not blocked on any network).
Recently moved in the UK. I got myself a pay-as-you-go SIM from Three3 provider for the 1st month, but later I switched to EE for a monthly plan SIM card.
Ever since I received the SIM card, I have noticed that the mobile data was not working.
I have changed my number to the was I had before using the PAC code and I thought maybe it is because of this process.
2 days later, after the number was ported, I still had the problem.
Contacted the support from Chat box and I also had a call with a 2nd Line support:
1. Settings -> General Settings -> Reset -> Reset Network Settings
Did not work!
2. Settings -> Connections -> Mobile Networks -> Network Operators -> Turn Off Automatic -> Select different network and then connect back to EE
Did not work!
3. Network settings updated through a message sent by EE support
Did not work!
4. Technical Support told me he has sent APN settings through a message. I entered on my APN settings and it's not there.
It's my 5th day without data and I'm already annoyed by this issue. All the other SIMs work for me, even my partner's one. It's just this EE that is not working and I simply don't get it.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-05-2021 11:09 AM
Hi Leanne,
I don't have this route in my app, sorry.
It's either Settings -> and no Data Menu (maybe network permissions or device and SIM)
or from Menu you go to something else.
Update:
Researching through topics here, I have found a link used to send VPN address/settings to your phone.
Since there was no VPN address on my phone, I found it odd. So I did it myself, I received the messages and installed it and now I have mobile data!
FINNALY!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-05-2021 10:52 AM
Hi @AlinMega
Could you log into your My EE app and select Menu then Settings and Mobile Data, is this turned on at the moment?
Speak soon 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-05-2021 11:09 AM
Hi Leanne,
Update:
FINNALY!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-05-2021 11:11 AM
Hi @AlinMega
Thanks for coming back and letting me know you have resolved this.
Do you have an option showing as 'Use mobile data' within your My EE app?
Leanne 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-05-2021 11:16 AM
Hi @Leanne_T ,
The only thing I have simmilar to that is "Use Phone contacts".
Settings menu looks like this:
Logging in
Device and SIM
Use phone contacts
Your address
Change Personal Details
Network permissions
Notifications
Log Out
The main menu is:
Current Usage
Bills & Payments
Plan & add-ons
Upgrade
What's new
EE Up
Settings
That's it.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-05-2021 11:31 AM
Thanks @AlinMega
If you have any further problems using data, I would suggest getting back in touch with our Tech Gurus on 150. They will look into this for you.
Leanne 🙂
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
13-06-2021 04:03 PM
Hi, I have out my mother onto EE from Virgin and she is having the same problem that you have described. Not mobile data connection. Do you have the VPN available for me to try on her phone?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
14-06-2021 07:53 AM
Hi @Dave85.
Have you tried some of the other troubleshooting steps above, for example a network reset on the phone?
Jon
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
29-08-2022 08:11 PM
Hi. I'm having the same issue setting my wife up on s8. Tried all above steps and tried changing settings on https://setup-ee.wdsglobal.com/internet nothing worked. Please could you send me the link for the VPN. My wife needs data within the week and if nothing can be done, she will have to use another network
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
30-08-2022 08:17 AM
Hi @TrailBlazer
I've recommend speaking with our Technical Support team so that they can help you get the data connection set up.
- Mobile data in Android Devices
- Roaming on iPhone 15 plus. in Apple Devices
- You must have a sim associated with an apple device for to be used for iMessage in Apple Devices
- Galaxy watch 7 LTE roaming in Android Devices
- All Rounder iPhone sim only plan, Apple Watch data add-on question in Apple Devices
