Locked Out of Phone
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-02-2024 08:50 AM
Hi everyone I think I probably know the answer to this but I changed the password on my S23 (had to as company portal said i should)
And yup you guessed it I can't remember it - tried all combinatons and now i think i need to factory reset. Did try in Find my Device but my old phone is there not this one. Problem is I can't unlock it to factory reset & if i follow the steps using the buttons it just comes back on.
I suspect a trip to the shop is coming.
NB I'd like to caveat all this by saying I have a new puppy and lack of sleep & brain fog is my defence - i even put the butter in the freezer yesterday!!!! 🤣
TIA
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-02-2024 09:10 AM
There's nothing more a retail shop can do to unlock an Android phone than what you can do - by design, if the phone is locked you need the PIN/password to unlock it.
Try the steps on Google Help too, there's a few remote recovery options outlined - https://support.google.com/android/answer/7663172?hl=en-GB
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-02-2024 09:16 AM
Thanks I think i've tried most of that - it was more help to factory reset which i seem to be incapable of doing!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-02-2024 02:26 PM
Does this Samsung Support video help, @MellyD1?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-02-2024 02:54 PM
Hi James thanks for this but its slightly more complicated?? So I can't unlock the phone as no pin, i can't turn it off as no pin and its in Airplane mode so i think it needs a hard reset which i believe it needs to be off so i have to drain the battery to do this??
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-02-2024 03:28 PM
Hi @MellyD1,
If you swipe down the notification shade on your lock screen and turn off airplane mode, are you then able to see it at Find your phone (google.com)?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-02-2024 04:15 PM
No need to unlock to turn off airplane mode 😞 honestly i'm in a circle of perpetual doom!
i did pop into the EE shop in Sunderland today hoping they had a fancy button to press and it was them that advised to drain and then hard reset
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-02-2024 07:42 AM
Hi @MellyD1
Can you try the steps on the How do I perform a factory reset on my mobile device? | Samsung UK page to see if you can use the buttons to factory reset, if not there is an option to contact Samsung for further support 🙂
