Is there anyway to get my Samsung A14 to auto contect to Hotspots?
Kizziecat
I live rural and many times have no signal at home or out and about.  I will change my mobile provider to EE from Three once my current contract ends.  But in the meantime, is there a way for my phone to connect to a hotspot when out, not a problem at home, as I can use other means?
Be kind as I'm old and not tech-savvy
@Kizziecat : As a New EE BB user you should be able to use the public EE WiFi for free. Just login to it with your EE a/c creds.
8 REPLIES 8
@Kizziecat  You’ll pay to use the service unless you are an EE customer.  You’ll need to pay first each time you want to use the service so unfortunately no you can’t automatically connect without payment first.
Thank you for replying, Chris.  I have my BB with EE.  I knew I had forgotton to mention something important
What is the name of the EE BB plan are you on including its speed?
Essential fibre 36
DL 29-32
UL 8-9
Thank you
@Kizziecat : Thanks! You're welcome 🙂 ! Glad I could be of assistance & trust it is now sorted.
Yes, it is, I tried it when I was with BT, but never seemed to work, but with EE it seems to work. Thank you again
Have a good weekend
