on 20-05-2024 10:43 PM
Solved! Go to Solution.
on 20-05-2024 10:48 PM
When was it bought new?
You can just check for unlocking by using the Unlocking your device form and giving its IMEI no., which you can obtain be dialling *#06# into its keypad.
