Google Pixel system error
GrimsbyMatt44
I need some technical help.
A Google Pixel we have keeps flashing up an error message that makes it hard to use.
It is about the android system intelligence. It keeps say it has stopped. How do we rectify this please and do you know what is causing it?
Matt
Leanne_T
Hi @GrimsbyMatt44
Thanks for coming here.
Can you try opening the Settings app, select Privacy, Android System Intelligence, then Clear Data.
Does this help?
Hi thanks for your reply. Those steps don't take me to Android System
Intelligence. I can't locate that on his google pixel.
Leanne_T
Which model Google Pixel are you using? @GrimsbyMatt44
Leanne 🙂
354-
Star Contributor
Star Contributor
@GrimsbyMatt44 - You should be able to use the search for that through the "Search settings" searchbar; tap/swipe intel; it should autocomplete and locate it.
