Daily alarms switching off, overnight?
peterg
I have four daily alarms set on my Motorola g7 power phone (also one weekly alarm) recently the daily ones seem to switch off (overnight?) - all four seem to switch off, the weekly one is OK. Can anyone suggest a couse for this?
13 REPLIES 13
peterg
For testing I restarted the phone and cleared the cache, tested the alarm a few minutes ago and all seemed OK. Thanks for the help but I will reserve final verdict till tomorrow morniing, if that's OK to ensure the alarms are still there in the morning, If so I'll mark this as the solution, cheers for your help and guidance.
peterg
Hi Chris the alarms seem to a) still be there the next morning and b) work OK.
I also , for the first of the four alarms changed the schedule from just todayto every day to remove the  possibility of not resetting it.
So as I say, all seems good. Thank you  for your help and guidance I will mark your last comment as the solution. Cheers again.
James_B
EE Community Manager
Thanks for the update, @peterg 🙂
peterg
No worries
