Daily alarms switching off, overnight?
peterg
I have four daily alarms set on my Motorola g7 power phone (also one weekly alarm) recently the daily ones seem to switch off (overnight?) - all four seem to switch off, the weekly one is OK. Can anyone suggest a couse for this?
Christopher_G
The other two things to try (you've probably tried the first already), are to restart your phone and clear the cache on your clock:
Go to Apps > Clock > Storage > Clear Cache.
I meant just to set an alarm, say in a minutes time, just to test if it works.
13 REPLIES 13
Christopher_G
Hi @peterg
Welcome to the community.
Is your phone on the latest software? Have you tried turning off the alarms and re-setting them up?
peterg
Yes, off then on again, restarted the phone, Software? the phone is android 10 ni forther update offered since then, though the apps are up to date.
Christopher_G
Is there a 'silence after' option in your clock settings, @peterg?
Do they always switch off since you noticed the problem, or do they sometimes work?
peterg
Hi there is a silence after option currntly set at 10 minutes - have not changed it was not aware of it before - I only notice quite recently, i may have put it down to personal error but four different limes is stretchin credulity.
Christopher_G
I've been reading a few similar threads on the internet, @peterg
Some users have said that their alarm clock volume had reset to zero, somehow. It may be worth checking that. Under Clock > Settings > Volume buttons - make sure this is not "Control volume".
peterg
Hi Chris, no my alarm and general volume are set to max, cheers.
Christopher_G
If you search 'quick settings' on your phone, can you find the 'say snooze' and 'say stop' settings, @peterg?
If so, could you switch those off and test an alarm please?
peterg
No cannot find those settings abd do not understand test "on alarm"
Christopher_G
