25-01-2022 08:57 PM
I'm having loads of issues with the Pixel 6 Pro, even after the latest January update, constantly having connection issues, some apps just don't have access to the internet and I want to just get rid of this rubbish phone, what laws can I use to make sure I can get out of this contract and return the phone?
25-01-2022 09:07 PM
Hi @elliottcoe ,
If you have a faulty device, consumer protection laws give you the right to have this rectified per the below links.
I would recommend that you base your claim on the device being faulty rather than something vague about whether or not it is for for purpose.
https://www.gov.uk/consumer-protection-rights
https://www.which.co.uk/consumer-rights/shopping/faulty-goods
https://www.which.co.uk/consumer-rights/advice/what-do-i-do-if-i-have-a-faulty-product-aTTEK2g0YuEy
https://www.citizensadvice.org.uk/consumer/somethings-gone-wrong-with-a-purchase/return-faulty-goods...
https://www.citizensadvice.org.uk/consumer/template-letters/letters/consumer-template-letters/letter...
https://www.citizensadvice.org.uk/law-and-courts/legal-system/small-claims/Problems-with-goods---let...
25-01-2022 09:35 PM
Seems like a widespread issue:
P6Pro - Anyone else have signal issues after the update? : GooglePixel (reddit.com)
26-01-2022 08:13 AM
Hi @elliottcoe
Welcome to the community. Sorry to hear that you're having some connection updates.
Could you try backing up your information and restoring the phone to factory settings. Let us know if it's any better after that.
26-01-2022 08:25 AM
@elliottcoe That’s what a warranty is for.
26-01-2022 10:46 AM
@Chris_B : The warranty never replaces your statutory rights.
26-01-2022 01:23 PM
@XRaySpeX Never said it did. Warranty gets the device fixed or replaced. Not fit for purpose 1 year after getting the device isn’t going to get anything sorted as the device wasn’t like that when received. And if anyone wants to go down that route you’ll need to get an independent report on the device at your own cost to prove the device was not fit for purpose when you got the device and the fault was there already.
if it’s a software update that’s caused this then that needs looking at and that starts with a factory reset as it could just be a corrupt install.
