24-01-2022 11:22 PM
Had a look online but appears this is an issue with Oneplus manufacturing & EE.
Whenever the phone enters a 5G zone the phone goes into a Crashdump mode, making the phone inoperable.
Sometimes this happens every so often, other times it's every 5 minutes.
There's been no update for these phones in a considerable amount of time, which I'm sure is long overdue by the EE network team on signing off an update.
Phone is completely fine to use elsewhere, only in 5G zones this happens. Hope someone can advise a solution as buying a phone on contract with yourselves to then not even be able to use 5G is just ridiculous if you don't support these devices anymore!
25-01-2022 11:56 AM
Hi @JoshH001 ,
Is there any option to force usage of 4G technologies on the device so that 5G technologies become a non-issue?
25-01-2022 08:00 AM
@JoshH001 looking over the internet it looks like One plus have dropped support for that device. All updates come from the manufacturer not the network the net just approves the updates.
25-01-2022 11:56 AM
Hi @JoshH001 ,
25-01-2022 12:07 PM
Thanks, figured out a workaround.
If you go to settings > sim & network > preferred network type > 4g, 3g, 2g auto.
This will force 4g only! 🙂
25-01-2022 01:30 PM
@JoshH001 Just tested my One Plus pro 5G in a 5G area and works for me, I’ve not used my device for a long time so I had to test this.
Looks like it’s your device that has an issue with 5G. Have you ever tried to factory reset the device back to stock to see if this issue is still present?
