150 text problem
Spikeymaria
Rung up 150 at the beginning of last month as if u text ba for balance to 150 it comes back saying unavailable when I spoke to ee they said they r aware of the problem n it should b sorted in a week n to keep trying but it still isn’t sorted and it’s annoying now can anyone help to fix this problem ?
Rach_H
Hi @Spikeymaria,
We know how important it is for you to know what is happening on your account, so I can appreciate how frustrating this must be. If you give our team a call, then they will be able to give you an update on what is happening, and let you know your balance.
Rach
15 REPLIES 15
Rach_H
Hi @Spikeymaria,
Rach
Patt1
Skilled Contributor
Skilled Contributor
I had this issue for over 3 months now & also when I text BILL to 150, nothing comes back. Spoken to do many agents at 150 & they can't help but raise tickets to the top techies etc. One people even said they are discontinuing the service while others said no but that they are aware of this issue. Nothing is being done.
Leanne_T
Hi there @Patt1
If this has been raised to the relevant team when you called, they will be investigating why you're not receiving texts from 150 and see what is needed to get this resolved for you.
Can you view your account information in your EE app or EE account online?
Patt1
Skilled Contributor
Skilled Contributor
Thank fully yes but this text service would help if I didn’t have access to mobile data.
Leanne_T
Thanks for coming back to me @Patt1
I would suggest getting back in touch with our tech guides on 150, they will check the ticket and see if they have an update from the support team 🙂
Patt1
Skilled Contributor
Skilled Contributor
Thanks but I am tired of chasing them up repeatedly.
Leanne_T
I understand @Patt1 and appreciate you have been in touch a few times.
The team are the best people to contact for an update to see when this will be sorted for you.
If you prefer you can raise a complaint using the Make a Complaint webform and the team will get back to you once the query has been looked into.
Patt1
Skilled Contributor
Skilled Contributor
Rang 150 again for the umpteenth time & having to explain it all over again, they either pretend it's a new issue or if they are aware, they just note it down but it's never fixed. This is ridiculous now.
Christopher_G
Hi @Patt1
I'm sorry to hear that you're still having this problem. Are you able to see your allowances in your EE Online account or EE App? Hopefully, you can see the information there, whilst this is being looked into by the technical support team.
