21-05-2021 12:14 AM
Hi everyone,
I have a huawei cpe pro 2 router with an EE sim in it providing 4g wifi to my house. I’ve got a bunch of smart home gadgets installed around the house which have all connected fine to the router
Unfortunately I have had no luck with connecting the Philips hue hub (v2) to it, i remember seeing a thread somewhere where someone had a similar problem with their Philips hue bridge and a 4g router and there was a mention of changing DHCP or DNS settings?
If anyone could help out as it’s driving me slightly mad that I have all these Philips hue lights which I can’t control with Alexa.. thanks!
21-05-2021 09:07 AM
Welcome to the community, @Alex198
What is the connection problem? Is it just not finding the router? Do you get any error messages or anything?
We'll do our best to help.
21-05-2021 10:11 AM
the bridge simply can’t connect to the internet. It’s plugged in via Ethernet to the 4/5G router I mentioned earlier, but the light that shows if it has an internet connection blinks instead of staying a steady blue light
thanks for the help!
21-05-2021 11:19 AM - edited 21-05-2021 11:21 AM
These Blue flashing light thingys, are they Flashing because they aren't connected to the Router or the Internet?.
You can check what is connected in the Routers Admin Home Page.
I would recommend anyone with a Huawei CPE LTE Router running an EE SIM to set the APN Profile to IPV4 Only.
How are you running the WiFi in terms of the Bands 2.4 & 5Ghz, are you running both together in Auto, if so, I would split them into 2 different Access Names this can help identifying connection issues.
Another thing to check is the WiFi Channels, in particular the 5Ghz Band is this set to Auto, if so which Channel ?, If the Huawei is a Global version it may Automatically set this Channel to 100 or above, meaning some Devices may not connect to these extended Band Channels, or find out what channels your Devices are compatible with and manually select those channels on the Router.
21-05-2021 01:24 PM
Hi there,
So I checked on the router admin page and the Philips bridge is connected properly.
The flashy light on the Philips bridge is because the bridge can't connect to the internet which from what I have read elsewhere it is something to do with the stock setup of these 4/5g routers.
So with the APN profile, if I change the EE internet default profile to specifically IPV4 only what would that do?
Yeah the wifi is split into 2.4 & 5 as separate access names,
So the 5GHz band is running on Auto (default), and the channel is also Auto,
Does any of the above help? I'm completely out of my league when it comes to internet knowledge so hopefully it helps direct us to a solution! Thanks again 🙂
21-05-2021 01:27 PM
Did you change it to IPV4 Only ?
22-05-2021 07:54 PM - edited 22-05-2021 07:54 PM
Sorry for the late reply @EssexBoyEE , yeah so I just changed it to IPv4 only, the light on the. Philips hue bridge is no longer flashing, it's just turned off now, Do you know if changing the router to IPv4 takes time or should it be an instant fix if it was going to work? Thanks 🙂
22-05-2021 10:15 PM
The time required to apply that fix will be the time taken for you to reboot the router as it's always good to ensure such changes survive a reboot. 😁
22-05-2021 10:21 PM
Hi there,
Got it - the bridge is still not connected to the internet then, are there any other ideas you may have?
If it helps, here is the link to another thread with someone having roughly the same problem as me and it was solved https://community.ee.co.uk/t5/4GEE-WiFi/4GEE-router-won-t-allow-Hue-Bridge-to-connect-to-the-interne...
Thanks again!
