we tv box
robert571
we tv box worked for a month, now it won’t connect to wifi, even if it responds with good wifi signal strength. I type in password & it fails to connect. I tried another box but same issue. I think they are useless
Midnight_Voice
@robert571
What’s ’we tv’?
Weerab2024
Scholarly Contributor
Have you tried connecting it with WPS? Once you select the option during setup you wouldn't need to press the WPS button at the side of your EE router.
How far is your router from your TV box that you are using? Sometimes the distance from the router could affect it.
You could also try powerline network adapters or a mesh WiFi system to extend your signal.
EE Apple TV box, EE mini box, Full Fibre 900, Sky Stream
hi my auto correct changed ee tv box to we tv box!
all is fixed now. when typing in router password you are presented with 2 “connect” menu buttons. 1 within the box where you type password & another one at the top right of screen. tried connecting using 1st button but constantly failed so used top right button and connected straight away.
Sent from Yahoo Mail for iPhone
