Yellow pause bar
swtrains
Valued Contributor
Valued Contributor
Let me be clear - I love my BoxPro - and find it a joy to use.
But……
I have one major beef and it is with the intrusive yellow pause bar! If I want to take a closer look at a detail in a scene and press pause, I instantly lose a quarter of my screen and it invariably blots out the detail I was wishing to see. So I have to rewind a bit and replay, ignoring how long the darned thing takes to fade out, so I can hopefully catch a fleeting glimpse of what I was interested in.
And after a movie, especially on TPTV, the cast list appears at the end. They often roll quickly so I hit pause, only to lose the bottom section of the list because, you’ve guessed, the yellow bar and screen shading has blocked it from view!
I do so wish there  was an option in settings where you could change the size, duration and screen position of this thing, thus removing my only complaint about this box. Am I alone in this or does it bother other viewers too?
DarrenDev
EE Product Expert
After pressing Pause, press Back.  This should hide the bar.
DarrenDev
EE Product Expert
swtrains
Valued Contributor
Valued Contributor
Thanks, Darren - will give that a try!
