Wifi box
Leannewilliams1
If I cancel my wifi box will be bill be cheaper
Weerab2024
Problem solver
Problem solver
By 'wifi box' if you mean the smart WiFi extender (which is white), you could but if you were struggling with WiFi coverage before you had it, it will revert to the coverage you had before.
You should maybe give EE a call and see what they can do.
If you mean the router (which is black) it gets a bit more complicated as you need a router for your broadband.
EE Pro TV box, Full Fibre 900
For EE contact details see
https://ee.co.uk/help/contact-ee
Or as this is posted under the TV it could mean an EE TV box. In essence all EE BB kit contains an element of WiFI.
So, @Leannewilliams1 , please be more specific as to which box you are referring to,
