Ee tv box mini
Jamesenty123
I’m currently with sky using their sky stream box but looking to move away as prices shooting up. I’ve looked at the currently deal broadband and tv by EE (BT), and it says I get a tv box pro, but I wouldn’t have space for that and would just like a mini box, is it possible to just get a mini box instead on its own?
Peter_W
Hey there @Jamesenty123, welcome to the EE Community 😊
I've had a check here, and you should be able to select just the Mini box at checkout, or you can also go for the Apple TV 4K option too.
Just be aware that these boxes only support TV over the internet, so you're not able to connect an aerial like you can with the Pro Box.
Peter
zulu17
Star Contributor
Star Contributor
Just to clarify  @Jamesenty123  if you took an EE TV package with EE broadband  you would have the Apple TV option which you should consider  as an alternative  to the minibox if space is a consideration. IF you take BT broadband the AppleTV box is not a current option when taking EETV.
Midnight_Voice
@Jamesenty123
Can’t you slot the Box Pro in where the now redundant Sky Stream box went?
Channels in IP mode aren't as vast as the EE offering so if you are after the U channels other than gold or alibi, you may want to weigh up just using the U app.
https://ee.co.uk/help/tv-sport/manage-use/channel-guide
If you use the pro box you can get  the fee to air channels with the pro box when set up in aerial mode but on the mini box and apple TV box you would need to revert to the U channel, which doesn't offer live feeds of the free to air channels
EE Pro TV box, Full Fibre 900
For EE contact details see
https://ee.co.uk/help/contact-ee
