Uktv app not working
Joanet
Is anyone else having problems with uktv app on EE TV.   Was working fine yesterday.  Now got error code 03-0005 .  Technical support cannot help despite trying.  Suggested factory reset if it doesn't reset itself
Although I've just tried the app on my Smart TV and it works fine and on my phone. So perhaps it's an issue with the app on tbe EE tv boxes? I have sent an email to the email address that appears with the error code, see if they reply
8 REPLIES 8
Garethrprice
Working fine here (Pro Box)
Steviet86
I am having the same issue
Andylev16
Same issue here for last 2 days.
managed to get it to work on my smart TV but not through the EETV box
Thanks. I can get on tablet, phone and firestick.  I emailed UKTv and got a reply saying  technicians are working on
. A lady from EE is supposed to be ringing me back today so I will see what she says.
Same. I can get it on tabletb, phone and firestick just not on EE.
EE  technical just phoned to check if it was  working yet and it is back up so hopefully yours is as well.
Dazra
Found this when I had the same problem.iknow this is a late reply but thought I'd add a fix that worked for me. Log out of the app and log back in it fixed it for me
