31-10-2024 07:43 AM
31-10-2024 12:05 PM
Hi @Krozen
Thanks for coming to the community 🙂
Was the router replaced for this reason?
Have you tried restarting the router and TV Box and trying to connect again?
Thank you.
31-10-2024 07:58 PM
A replacement hub will have a different SSID and password from your previous hub. Have you taken this into account?
05-11-2024 12:30 PM
The hub had to be replaced as it would not power up, it might have been the power supply but I couldn't check.
Almost everything is back up and running using WiFi connections in lieu of hard wiring except my network audio device, which does not have WiFi capability. I am going to try a WiFi extender with an ethernet connection for it next weekend.
My printer was set up with a hardwired connection to the hub but despite re-entering the hub password it won't connected. Thankfully my home server is operational with a direct connection into the hub.
Cheers, Ken
05-11-2024 02:53 PM
Your hardwired printer connection shouldn’t need a password, it should just work.
If you are having to put a password in, is it possible you are trying to connect it over WiFi still?
