TV Box Pro. Does it need to be turned on ie blue slight showing to record
Timlloyd1957
wgwright
Expert Contributor
Expert Contributor
As long as the box is connected to the TV and to the mains it does not need to be switched on - it doesn’t need to have the blue/green lighting the front showing, then recordings should take place
wgwright
Expert Contributor
Expert Contributor
