TV BOX PRO No Dolby Vision
Rikki75
Ive ordered the TV box pro and disappointment to find out that it has no support for Dolby Vision or HDR10.  When I watch movies on my TV that are in Dolby Vision or HDR10 my TV informs me of that format.  But when I switch to my TV box pro and watch the same content, it just appears as HDR as standard.  Is there any TV box at all from EE that supports both HDR10 and Dolby Vision as these are the best 2 picture formats.
Rikki75
DarrenDev
EE Product Expert
None of the EE TV Boxes support either HDR10 or Dolby Vision.
You can swap to the EE TV Apple TV instead, which supports HDR10+ and Dolby Vision, however you'll lose the ability to record. You need to decide what's most important to you.
