Slight lag when changing channels on TV Box Pro
EddG
im just wondering if anyone else has noticed. I can’t tell if it’s an issue at all. Or if it is to do with the internet speed or box software. But if I flick the channel up or down on the Box Pro it has a lag of 4 seconds. It’s on internet mode.
compared to Freesat which is instant when changing channels. I think possibly it’s just a limitation of the multicast streams.
I phoned tech support who said it shouldn’t take that long. But one of the managers on the floor said he experiences it and they reckon it might be a faulty batch. Ethernet vs WiFi is the same.
WiFi speed is around 68-73 Mbps throughput.
many thanks,
edd
Regards
Edd
zulu17
Problem solver
Problem solver
hi @EddG is this when going up/down one channel only or are you doing multiple  presses of the up/down to reach your desired channel ?
EddG
Hi Zulu,
Up/down one channel only.
Regards
Edd
