Sky Sports Channels keep freezing
Transistorhero
Why do the sports channels freeze, tell me there is a broadband issue, then start working when you click up a channel then back to the one you are watching
For live sport, it really ruins the experience
Peter_W
Hey there, @Transistorhero
How is your EE TV box connected at the moment, via WiFi or Ethernet?
Also if you haven't already, I'd recommend trying a factory reset on your box.
If you check out our help page here, there's an option you can choose that allows you to keep your recordings when doing this.
Peter
Peter_W
Peter
WaveyDavey59
Valued Contributor
Valued Contributor
Just curious but did you get it fixed?I have same issue.
