07-11-2024 06:32 PM
My previews are unavailable
07-11-2024 07:13 PM
Previews of what?
What exactly are you doing, what do you expect to happen, and what does happen?
07-11-2024 07:26 PM
The words come up but there is no picture profile showing in the little picture squares. It says there is an error code 102
07-11-2024 07:29 PM
It says cannot connect my broadband.
07-11-2024 07:44 PM - edited 07-11-2024 07:49 PM
Actually, it says YVM102. The YVM Is important.
And it means the box can’t connect to the internet.
Try:-
https://www.bt.com/help/tv/what-do-the-bt-tv-error-codes-mean-
Put the code in, do what it says.
Do not take the ‘helpful’ suggestion to use the TV and sport help tool, as EETV have either forgotten to write it, or forgotten where it lives 😢
