on 03-05-2026 07:49 PM
Hi I've been using discovery + and then hbo max to watch tnt sports. When I try to use these apps now on my firestick it says both need a update. This then takes you to appstore and it says its unavailable. Though my firestick is devices compatible. When you open both hbo max app and discovery + it just buffers on update. Really frustrating. That's 4 day's now.
Solved! Go to Solution.
on 04-05-2026 08:57 AM
@Jason1873 we cannot support the apps I'm afraid, however I recommend you just remove the apps and then install them again.
