on 11-12-2024 01:37 PM - last edited on 11-12-2024 02:52 PM by Christopher_G
I moved from BT to EE with the start date 2024/11/08. On the top of the default TV service I have requested extra services namely: Now Cinema Membership and Now Boost. None of the extra services are up and running since. Although I have called EE numerous times to solve this issue, apart of I managed to get the following complaints ref no. from my last call: V0L013-********** and V0L013-*********** I have no agreed service provided nor communication from EE of any kind since. This is now over a month since I have joined and nothing happened... I believe I am rightly frustrated...
[Mod Edit: Removed order numbers from public view]
on 11-12-2024 02:11 PM
Welcome to the EE Community,
unfortunately there is no account access here on the community you will need to call customer services on 150 or 0800 079 8586 and a EE guide will be able to escalate your issue for you.
David
on 11-12-2024 04:10 PM
David,
Thank you for your prompt response. Unfortunately this is the issue. I rang EE numerous times but not going anywhere whoever I speak with. Always the same answer..."This is something I cannot fix I pass it over to another team"...I only have the 2 reference number as my last call the gentlemen kindly provided as he recognised my frustration as I have no evidence of my calls at all....The biggest issue is no communication from EE side but stupid advert to buy this and add that....Is there any way to make a formal complaint?
on 11-12-2024 06:26 PM
Hi @Kokassosnyaloka
I understand your frustration, I'm really sorry this hasn't been sorted for you and you aren't being kept in the loop.
You can find all the ways to make a complaint here Make a Complaint | Contact Us | EE
Lesley
