Live TV will not work but apps work fine
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
07-07-2024 12:06 PM
I have recently changed from BT TV to EE TV and set up a pro and mini box in two rooms to receive EE TV via wifi. Neither TV has an aerial connection nor an ethernet cable connection. During the set up process each box 'found' 133 channels.
I can view anything via my apps so obviously there are no problems with the broadband speed , wifi or cable connections etc. However live TV does not work at all. I can see the guide with loads of channels but when I try to play one I just get a black screen initially which changes after some time to just a very heavily pixellated version of the screen with either no sound or an occasional squeak. Interestingly the black screen on BBC shows the green button in the top right hand corner but nothing else until the pixellated mess shows. I therefore cannot record anything on the pro box because it says it cannot record anything playing in an app. It is exactly the same problem with both the TV box Pro and the TV box mini.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-08-2024 03:09 PM
What error specifically are you seeing @barbara011 ? When you try to watch a channel, what error is shown on screen?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-08-2024 03:37 PM
It says there is a problem with the broadband check connection and restart router IPC6023. Checked and restarted multiple times, plus new router but does not resolve. Apps all working fine
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-08-2024 04:09 PM
Sorry to hear that @barbara011 - that's the most difficult of errors, as it has so many potential causes.
I've raised a fault for one of our specialists to investigate - someone will be in touch hopefully in the next couple of days. Sorry for the inconvenience.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-08-2024 05:34 PM
Thank you, there is quite a saga of errors on the account since this issue cropped up and I do want/need the correct box, which apparently can’t be ordered for a few days. However, that aside, it does sound like a bug related to the broadband upgrade as others experienced a similar problem. I hope your specialist can resolve because to date I have been very pleased with BT/EE service after moving from Virgin last year.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
05-08-2024 08:54 PM
This has happen to me today. Live tv stopped working, can see the guide but when you click on a channel just a black screen. All apps are working fine. I have EE router and EE box literally next to each other. Mini boxes in bedrooms also no longer show live tv. Worked fine since April.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-08-2024 08:42 AM
@Don977 - did this also happen with an upgrade to full fibre?
@DarrenDev - something to check out with the specialists if these faults are occurring with the broadband upgrade. ? configuration of the router, the boxes, speed etc???
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-08-2024 09:40 AM
@Don977 the black screen should eventually show an error if you leave it long enough. Do you see this? You've mentioned apps are working fine - could you please try the EE TV app, and then try to watch something (e.g. a trailer).
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-08-2024 09:42 AM
@barbara011 we'll look for the root cause after we've established exactly why it's not working for you. Your issue is different to the original post on this subject, and is almost certainly different to Don's too.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
24-08-2024 12:00 PM
Hi Darren
I had the full fibre upgrade 4 weeks ago, and since then have had a new hub and new TV pro box. Neither have resolved the issue and I have been without live TV for a month. My EE guide referred the matter (code IPC6023) to second live support on the 16 August but I have not heard from anyone yet. Can you assist please?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
24-08-2024 12:52 PM
Sorry that your fault didn't get the correct attention from the start with @barbara011 however I can see the fault that has been raised, and it's with the correct team now. They do have a queue of between 7 and 10 days at the moment, so they should pick up your fault in the next few days.
