07-11-2026 09:53 PM
Reading around in this forum, it looks like I am not the only one with this issue. I switched to EE TV & broadband from Virgin last week (due to a house move). The broadband speed is down on what Virgin can provide (despite claiming to be faster), but my big issue is with the live TV, which freezes after a few minutes. I switch TV channels, but then it freezes again after a short time. The software in my set top box is up to date. I have rebooted both it and the modem. The set top box is connected to the modem via WiFi which passes through one wall, but only 3 metres away. What more is there to try?
08-11-2026 03:59 PM - edited 08-11-2026 04:44 PM
Hi @RichardB69
Welcome to the community.
I totally get the frustration, especially when you've only just switched and expected everything to work smoothly.
As the TV box is connected over WiFi, I'd be tempted to focus there first. Even over a short distance, a single wall can sometimes be enough to introduce interference, particularly for live TV streaming.
If possible, are you able to temporarily connect the TV box directly to the router with an Ethernet cable and see if the freezing disappears. If it does, you'll know the issue is WiFi related rather than the TV service itself.
It also worth running a broadband speed test near the TV box and compare it with the speed you're getting next to the router.
If Ethernet solves the issue but cabling isn't practical, an EE WiFi Plus Disc or relocating the router can often improve streaming stability.
Let us know how you get on.
Michael
08-11-2026 04:42 PM
@RichardB69 I notice that your fault is VERY specific. The channel stops working after 191 seconds each time (but not ALL the time). Given how precise this error is, I suspect there may be something else involved - I've asked one of our technical experts to take a look, as it seems too much of a coincidence for it to fail at that same point every time.
10-11-2026 11:48 AM
I've analysed every other set top box, and no-one else is seeing this same issue, so it's something specific to your setup.
Can I ask you to please test something for me? I see you have a number of other devices connected to your hub, including phones, tablets, laptops, a printer, and a smart home device. Can I ask you to please turn them ALL off, and see if you still experience the same issue? If it goes away, turn the devices back on one by one until the problem comes back. I suspect that something is broadcasting on your network and causing the signal to be killed.
