Help with tv channels
magicjope
I have just changed to EE from sky but cannot get YouTube or Talk Radio/TV. Does anyone know how to do this?
DarrenDev
EE Product Expert
YouTube isn't currently available on the TV Box Pro or TV Box Mini.  If you took the Apple TV option then you should find the app is available.
Talk Radio and Talk TV are available on the TV Box Pro if you're using it in aerial mode (i.e. with a TV aerial connected).  If you're using Internet Mode, I'm afraid they're not available.
Nelsonpk
I’ve just done the same i.e sky to ee box pro and would like talk tv, qvc etc I have no ordinary aerial only the facility to connect my tv to a sat dish and use freesat. I see you said if you have the Apple TV option I assume that’s the app and not the Apple box. If it is the app I have hunted high and low win the app through the ee box and I can’t see talk tv app can you you help?
zulu17
Star Contributor
Star Contributor
YouTube was added to the Box Pro earlier this summer.
This addition also actually allows you to access Talk Tv /Talk Radio on the Box Pro  via YouTube. Just search for Talk within the YouTube app.
@Nelsonpk
It’s the Apple TV box that EE TV offer as an alternative to the Pro box,
As you probably know, EE TV doesn’t operate over Freesat.
