21-03-2025 04:25 PM
Pretty much the title. When I had a Sky Q box and turned it on, my Sony Bravia would turn on AND default to the Sky input.
With EE TV Pro. I turn it on, Tv turns on but it stays on the Bravia Home Screen. I have to fiddle with the Sony remote to select the input for the EE TV Pro box.
Anyone know how I can get the turn on behaviour to default to what channel is currently on EE TV when I switch it on.
22-03-2025 09:11 AM
Hi @Cosmic68
Welcome to the Community
For turning your TV on, this should happen automatically via HDMI-CEC. Some TVs only support this on specific HDMI ports - is it in the same port that the previous box was? Are you able to try different ports?
For turning the TV off, you need to hold the power button for 2 seconds - this should then turn the TV Box and TV off. If you just press it briefly, it'll only turn off the TV Box.
Have a look at How to use Bravia Sync / Control for HDMI
Ali
23-03-2025 05:08 AM
Hi thanks.
yes the EE remote switches on/off the Sony tv.
what I’m asking is: when I use the EE remote to switch on tv box-how can I get the Sony tv, when it also switches on, to default to the HDMI channel the EE box is playing tv through. Sky Q used to do this.
what happens is everything switches on but the tv stays on the Google/android homepage.
23-03-2025 09:57 AM
@Cosmic68 It should automatically switch over to the corresponding HDMI to match the EE box.
Do you have the EE box connected to the same HDMI port that the Sky Q box used to be connected to?
Ali
23-03-2025 11:34 AM
Hi yes I do (HDMI 1).
I’ve tried on different HDMI’s and it’s the same.
its possibly a question for a Sony forum I guess.
23-03-2025 11:57 AM
@Cosmic68
Have you had the chance to go through your TV Brivia-Sync settings, by following the link above?
Ali
