Error code IPC6023
dan06567
I received the EE box pro on Tuesday 30th April and activation began on 1st April. I'm using Internet mode to watch HD channels. But it give  me error Error code IPC6023 for every channel. Can someone will help me?
25 REPLIES 25
humeka
That may bypass the problem , but not using WIFI isn't the solution.
I didn't have this problem until I changed from BT to EE and the router changed... EE TV is connecting using 5 GHz so the signal must be strong enough otherwise it should revert to 2.4 GHz
It's really annoying happens once or twice a week now .. on NOW Sports (440 Channels) and on the NOW App plus others
Because of the way BT/EE TV uses Multicast protocols I can't use my EERO WIFI mesh
EE Full Fibre Gigabit, Smart Hub Plus, EE TVR & Mini Box ,4 Digital Voice ALEXA Advanced Phones, 6 EERO6 Mesh ,10 SONOS Speakers,5 Reolink Cameras, AES Access System, 3 HP Windows PCs, 2 Samsung Tablets, Samsung Phone, SMARTTHINGS/Hubs,SharpTools,TinyCam, HIVE,SOMFY,FIREANGEL,KASA,TAPO,FUSION360,Creality 3D Printer & Scanner, 10s of Zigbee smart devices.
humeka
Update on my IPC6023 Errors which happens 2 or 3 times a week and I can recover by switching channels , restarting TV Box or restarting APPs .
Customer Support wanted me to reboot my router (they'd already reboot the YOUVIEW box remotely)  .... Their answer is ALWAYS turn things on and OFF .... that's no way to diagnose a fault !!!! It just will happen again because there's an inherent issue. So they are passing it on to TMC (who I discover are a "virtual" office of supposed experts sat at Customer Service Sites !!).
I get a call back a day later ... TMC will not deal with it because I refuse to do their power off/on solutions .They seem incapable of gathering diagnostic information , running traces or taking memory dumps... very unprofessional . How on earth an intermittent problem will be solved with their switch off/on approach is unbelievable.
Meanwhile I'll take the TV box off the WIFI connection and hardwire it through an Ethernet connection and I'll bypass the problem ...NOT FIX IT
Lancashire72
My t.v is not working
@Lancashire72 we are aware of an issue affecting TV service in your area. It is being worked on, and should be fixed very shortly.  Sorry for the inconvenience.
Kalowski
Same error today here in Manchester. Reading this thread does not fill me with much hope.
I will not be having a happy conversation with EE tomorrow and will be expecting a refund if this takes any time at all.
@Kalowski no need to call - I can confirm that our automated monitoring has already picked up the fault in your area, and Openreach have already been notified. I would expect service to be restored later this morning.  Sorry for the inconvenience.
