Error code -200 - unable to load
BelindaC
When trying to get into the Disney Channel and YouTube it comes up with error code -200 unable to load.
Netflix the same but with code NW - 4-8
any ideas?
zulu17
Star Contributor
Star Contributor
@BelindaC
For Netflix there is information for that error code at
https://help.netflix.com/en/node/14451
Given you are having pronblems with several  streamers restarting you device and network seems sensible.
Which device are you using and are you able to use an alternatiuve device tocheck if that works ?
