Ee tv box
Peteb1973
Hi have ee tv running in aireal mode but keep getting poor signal loss of picture but if i run aireal straight to tv and bypass ee box perfect picture any ideas thanks
Timbo45
Skilled Contributor
Skilled Contributor
@Peteb1973
The usual way of setting this all up is to have the TV Aerial lead into the box & then another lead from the output socket of the box to the TV's aerial input.
This does require that the Antenna Out is set to ON in Picture & Sound in the settings.
Some might have a splitter to split the aerial feed to both the box & the TV but this can drop the signal strength and for some this can cause a problem.
With these boxes a weak signal or an overly strong signal can cause similar effects as the tuners on all the BT/EE TV units are not as solid as they should & nowhere as good as in a TV.
Go into Setting & TV Signal Quality and see what the quality & strength figures are on one of the channels having the problem. Ideally we want 100% quality and , say, 80-90% strength.
Based on this what is your setup and what figures do you get strength & quality as I've mentioned above?
Timbo45
Skilled Contributor
Skilled Contributor
@Peteb1973
So is it the picture quality when viewing via the EE box or when using the TV direct that's the issue?
When useing ee tv box poor signal loss of picture
Christopher_G
Hi @Peteb1973
Welcome to the community.
Could you check to make sure the aerial cable is attached correctly at both ends please? It's also worth checking to make sure there are no kinks in the cable.
If it all seems fine, and you're still having problems, try restarting the TV box.
Timbo45
Skilled Contributor
Skilled Contributor
@Peteb1973
Seems a lot better thanks for your help
