EE tv mini box
Laurasuzanne
Received all my stuff for setting up EEtv main box works perfectly. Only issue is the mini box is struggling to pick up the WiFi and says connections weak. Running an Ethernet cables not an option. Any suggestions to help or am I likely needing to enquire about WiFi booster?
DarrenDev
EE Product Expert
The official EE product to support this is: https://ee.co.uk/broadband/smart-wifi
Powerline adapters may also work for you, but it depends very much on the product you choose and the electrical wiring in your home.
You can also purchase other wifi products, however they won't be supported if anything doesn't work.
