EE tv controler
Estebans20
My controller has suddenly stopped working even after changing batteries the light on the control does not even turn on
zulu17
Star Contributor
Star Contributor
Hi @Estebans20
The EETV  advice is  described at
https://ee.co.uk/help/tv-sport/fix-problem/my-remote-is-not-controlling-the-ee-tv-box
If the fixes don’t work then reporting the problem to EE would be necessary.
In the absence of a working remote  it is possible to connect a USB keyboard to the box as this is one of the Accessibily options of Youview Boxes. Key matching charts for various keyboards are available from either the EE or Youview support pages. Older Youview (BT)  or Humax device remotes may also operate the box  to varying degrees. The EETV app if paired to your box can be used to set recordings.
zulu17
Star Contributor
Star Contributor
Hi @Estebans20
