17-10-2025 03:11 PM
Just received an extra mini box for an upstairs room. Despite a booster being in the next room to it, I can't get the mini box to connect over wifi. Do I need yet another booster box !
17-10-2025 04:18 PM
It depends on the layout and structure of your home. If there's no signal in the room, then it cannot connect.
It'd be worth taking the box nearer the hub temporarily and confirming it works there. Once connected and set up, you could then put it in the desired location and confirm whether it works.
