01-06-2024 08:50 PM
I just got EE TV but only get channels 320 to 463.
Any idea what could be wrong?
I was told I don’t need an TV ariel.
01-06-2024 09:00 PM
Which set top box did you choose? Apple TV, TV Box Pro, or TV Box Mini?
01-06-2024 09:57 PM
I believe you need an aerial for freeview channels. (I did, but they may have updated since then (2020). You should be able to get on demand stuff though. All depends on the package you bought.
02-06-2024 10:41 AM
If its the Pro box did you set it up with arieal plugged in and remove it after? You would need to reset it with the arieal unplugged and select IP mode during setup.
Surely the mini box or apple TV would setup in IP mode by default as there is no arieal connector
02-06-2024 12:32 PM
I got the Apple TV box.
03-06-2024 04:30 PM
@shy_mocha I can confirm that this issue is now resolved, but unfortunately you'll need to factory reset your Apple TV. When it comes back up, it'll be properly recognised as an EE TV Apple TV, and provide access to all channels.
Sorry for the inconvenience.
26-01-2026 11:37 AM
I have exactly the same issue. Yet my mini box shows more channels?
26-01-2026 11:42 AM
@Liz247 your TV Box Pro is in aerial mode (i.e. there's an aerial connected to it), however that aerial isn't providing any signal - so no channels were found.
You either need to get the aerial fixed, or disconnect it and factory reset the TV Box Pro to put it into internet mode.
