24-06-2026 09:51 PM
Does this happen to anybody else ALL THE TIME. So frustrating
24-06-2026 10:25 PM
I've never seen that screen before. Are you sure it's not your Smart TV menu?
Try pressing the TV Guide button on your EE TV remote.
25-06-2026 11:45 PM - edited 25-06-2026 11:46 PM
I wonder whether it might be that Youview data is not being populated on a home page perhaps due to an issue in recognising the location/type of service that is relevant to the box/ip address
26-06-2026 08:40 AM
I've never seen it look like that though. If it's offline, or not connected to a supported line, it shows an offline screen. If it's still loading , it shows a properly rendered screen with gaps where the data will fill
I've never seen it get stuck like that.
