EE TV Mini box not showing any channels in guide
Scorpioxx
I have just subscribed to EE broadband with TV package , with the EE Pro box and a EE TV mini box. The main box has set up okay , but when I have tried to set up the Mini Box , it is not showing any live TV channels.
if there is no TV aerial input , where does it get the channels , how do you tune them in?
thanks
Weerab2024
Scholarly Contributor
The channels are streamed over the Internet, try resetting the box (by going to the cog when you press the home button) and it should go through the process of finding the channels.
If it doesn't, how far is the router from the mini TV box?
EE Pro TV box, Full Fibre 900, Sky Stream
Weerab2024
Thanks , that worked a treat
