EE TV Mini box in TV bed
sideshowbob12
Am I able to put the Mini box in a TV bed? I'm just wondering if you can operate it easily with the remote and that it will still pic up the internet channels easily?
Peter_W
Hey there @sideshowbob12 😊
Welcome to the EE Community!
With the EE TV Mini Box, the remote is paired via Bluetooth, so you'll be able to use this without needing to have direct line of sight.
As for the TV Bed, this is a bit more difficult to say for sure, as it'll depend on what your setup is like.
To use your box wirelessly we recommend being no more than five meters from your Hub, with no more than one wall, ceiling or floor in between.
I know a lot of TV beds will have a dedicated shelf / drawer for media boxes too, but I'd strongly recommend making sure your box has sufficient ventilation.
The TV Mini Box is designed to monitor its temperature and shut down if it's running too hot, but we strongly advise keeping it away from any potentially flammable environments.
Please check out the full device guide here for more details!
Peter
Peter_W
Peter
Thank you
TommyGH123
Yes, because the EE box mini only works on wifi it is perfect to use on a bedroom tv as long as your tv has an HDMI socket. I hope that helps you
