EE TV Internet mode
Tjs9
hi, recently got EETV Pro box, I have no aerial so  have set up the box I’m assuming in internet mode. Unfortunately most channels like BBC, ITV Channel 4 etc are not showing up.
I have tried factory reset via the menus and also tried retuning the channels.
Any ideas how to rectify please?
DarrenDev
EE Product Expert
What's your TV activation date? The channels should appear the morning after that.
My activation date was the 21st
DarrenDev
EE Product Expert
According to our logs, your box isn't in Internet Mode - it's in aerial mode, so the only channels you're seeing are the subscription channels.  You've mentioned that you don't have an aerial - did you connect any cable to the aerial port?  If so, disconnect it (regardless of whether than cable goes anywhere) and try factory resetting your box again.
