EE TV Box apps down??
Stevemutton123
I had EETV for few weeks and honestly been awful
Perfect broadbans but having to constantly reset and power on and off to get it to register
This morning i now have MVM900 error where no apps are loading. I have all channels so know full well internet working
Im a broadband engineer so know internet ia fine. Reset this and thatall uodates. Just no connection to eetv box. Someone help or is this national outtage going on??
manatarms84
Expert Contributor
Expert Contributor
It won't be a national outage - it sounds like your TV box does not realise its connected to the internet fully.  Its odd its only effecting the apps but still.  I would firstly refresh your connection in settings go to the Broadband connection option and reconnect via there.  Failing that I would power off your broadband fully for 3 minutes along with your TV box and turn everything back on and that should fit it.  If you are using a set of power line adapter plugs to connect your TV box and broadband box together then a reset of these would also be a good idea.
zulu17
Star Contributor
Star Contributor
Hi @Stevemutton123
Is it  perhaps YVM900 rather than MVM900 error code.
(any EE personel reading may wish to feedback that the error code list on support pages are missing some error code)
You mention a series of issues and doing resets.
Error code explanations often indicate the most likely causes of the error rather than the full range of possible causes.
If you did a full reset then as part of the subsequent ox setup would be an acceptance of various  t&c 's  including those of Youview. If that was missed then subsequently in use it would create a scenario where some services (eg apps)  would not function.
Alternatively there might be a problem at the Youview end if you believe your own in house connections are fine.
I would suggest a  further full factory reset and subsequent report each and every fault you subsequently  encounter.
