EE TV App Issues
Timbo45
Expert Contributor
Expert Contributor
Recent updates to the App on iOS seem to have caused a pairing issue.
Mine frequently comes up Lost Connection with the options to Cancel a recording request , Pair again or Send Anyway - which works. In settings it states Connection Stalled.
Version is 7.1.8
DarrenDev
EE Product Expert
Do you have any more details on your issues @Timbo45 ? You only posted a title, with no message
Timbo45
Expert Contributor
Expert Contributor
@DarrenDev
Not sure what happened there but corrected now.
DarrenDev
EE Product Expert
I can't see an active EE TV subscription, to be able to find your device.  That's OK though - it's not a requirement to use the app.
Could you please let me know the device ID shown at the bottom of the My TV -> Settings screen, so that I can see what's going on with your pairing.
Also, one question: do you turn the power off to your TV Box when not using it?
Timbo45
Expert Contributor
Expert Contributor
@DarrenDev
TV & Box etc were turned off every night but not now. The box is now in deep sleep overnight to minimise power consumption.
Correct I do not have a subscription & the device ID is 2C0D9A59.
