24-05-2025 03:13 AM
I have an EE contract with Discovery Plus. Everything was working fine, but recently this message has been appearing, even when I’m using mobile data only. Is there any solution or way to fix this?
25-05-2025 01:33 AM
I try with my TV and work, then uninstall and install the app on my phone again and restart. After that it’s working again on my phone, so I don’t what happen there but it’s working again. Thank you
24-05-2025 09:09 AM
Hi @pinalopes.
Welcome to the community.
That is a bit strange that it is only happening on mobile data.
Can you try to restart your device, and if that doesn't help, try to delete the app and install it again to see if that helps?
Michael
24-05-2025 10:45 AM
If you have a VPN it might be causing the issue
24-05-2025 01:23 PM
Done it already and the problem still there
24-05-2025 01:24 PM
I don’t have a VPN, this tends to happen with nba or MotoGP content on discovery plus
24-05-2025 03:20 PM
Thanks for giving that a try for us, @pinalopes.
Is there other content that you're able to watch without any issue?
Also have you tried logging in via a different device to see if this gives the same issue?
Peter
25-05-2025 01:33 AM
25-05-2025 02:40 PM
Thanks for the update here @pinalopes.
I'm really glad to hear that managed to sort it out for you 😊
Peter
14-07-2025 08:55 PM
Hi Peter
rather than make a new thread I thought I’d raise it here. I have the same error code only for past UFC content. I’ve tried deleting and reinstalling restarting phone and clearing cache. Still not working
can you help
15-07-2025 08:33 AM
Morning @Gazwonder
Can you access past UFC content on any other device, when logged into your discovery+ account?
Do you have TNT Sport included with an EE TV package?
Speak soon 🙂
